Lift Kit/ Wheel Question
http://www.bushwacker.com/fender.asp...search=Search#
Both types, flat and pocket provide extra coverage.
http://www.quadratec.com/products/12510_600.htm
Xenon wider flat style
I'm sure there are more, should be able to get wider tube flares too.
The zenon is practically the same as bushwacker, but wider. I have seen both. Both are flat and give more gap in the wheel well. Zenon is definitely wider, but looks just like bushwackers. Also, bushwacker are a harder plastic, while zenon have more of a rubbery texture that has a little flex in it. Good luck with whatever you decide!
The Bushwacker Flats use stock mounting points, integrated wheel well coverage, tend to pop off of fender when hit instead of damaging fender. But are not as wide so do not cover wheels with 3.75" backspace.
Why I would buy the Bushwacker Flats if they were wider. I'm not comfortable with nutcerts. Not a fan of the Pockets.
