Lift Kit/ Wheel Question
So this might come off as a dumb question but i am going to ask it anyway. I have a 2012 JK with a Teraflex leveling kit. I am currently running 295 70 R17 Nitto Trail grapplers with after market XD Addict wheels with i believe 4.5inch backspacing. I currently reside in a state (PA) where you can not have any tread sticking out past the fender flares. My tires currently stick about 1.5 inches out past the fender flare. I was thinking about going back to my stock rims but I see a lot of people use 1.5inch wheel spacers because of rubbing issues. So my question is this, If I were to return to stock wheels with 1.5 inch Wheel spacers would my tires stick out past my fender flares? And if they do stick out how far and is there any setup that I would be able to run those tires on stock wheels without them sticking out and rubbing? Thanks
Yea, I thought about wider fender flares, There is nothing that i currently like but I am thinking about getting a custom made set. A local 4x4 shop said that they could make me a set of metal flat fender flares. I wanted to make sure that there was no other way before I break the piggy bank. Thanks for the advice guys
But a 9 inch wide wheel with 4.5 inches of BS is gonna stick out farther (2 inches) than a 7 inch wide wheel with an effective 4.5 inches of BS. (I believe the stock wheels are 7 inches wide??)
You don't think that two inches of wheel width is gonna make a difference? With the same backspacing, the 9 inch wide wheel itself will stick out two inches farther. This is gonna pull the tire outward also. While the tread width isn't going to change, the sidewall buldge will.
