Lift Kit under $1,100
If you are planning on adding a lot of weight, coils would be the better option. But mostly it's just personal preference. Many people think spacer lifts work just fine, especially considering the price. And other people say they wish they had started with coils, instead of paying for a spacer lift and then replacing it down the road.
And if you do decide on coils, do some research so you have an idea of what actual lift height you can expect. (2.5" coils could put you over 4", 3.5" coils could be closer to 5". Depending on mfg/model/load/etc). Obviously, the taller you go, the more issues you introduce that may need to be addressed.
Most people think they run a lot of travel, when in fact they don't. They get the extra flexy kit and big tires, then add a bunch of bump stop so they can clear the tires and end up with the same or less travel than a stock JK.
Budget boosts are simple, easy to install, and cheap. They are also easy to sell used. Why not start there and learn over time what isn't working and then plan the next build after that.
The spacer kits work great and make everything really simple. Coils can be complicated. Depending on the weight of the Jeep, they may ride nice or stiff and will rarely give you the advertised lift. Toss some Rock Krawler 2.5" coils on a 2-door and you can end up with 4". Now you have lots of issues to deal. Do you flip the drag link? Raised track bar brackets? Etc. You gain very little with coils unless you are truly able to run more travel than the stock coils.
Not that my opinion holds any weight but I would go with a teraflex leveling kit (pucks and longer sway bar links) and Metalcloak overlines until I could afford the 2.5" GC. I say this knowing that eventually I want flat flares anyways and they say you can run up 37's on stock suspension with those fenders. My preference also leans towards getting as much tire under the fenders with as little lift as possible.
The teraflex 2.5" is available with 9550 shocks for less than a grand. Its a great lift and product customer service is second to none. 35s can fit with this lift, but if your daily driver, I would suggest keeping the tires at 33's. It makes it much better for everyday living. the 2.5" lift is perfect with 33's imo.
The spacer kits work great and make everything really simple. Coils can be complicated. Depending on the weight of the Jeep, they may ride nice or stiff and will rarely give you the advertised lift. Toss some Rock Krawler 2.5" coils on a 2-door and you can end up with 4". Now you have lots of issues to deal. Do you flip the drag link? Raised track bar brackets? Etc. You gain very little with coils unless you are truly able to run more travel than the stock coils. Most people think they run a lot of travel, when in fact they don't. They get the extra flexy kit and big tires, then add a bunch of bump stop so they can clear the tires and end up with the same or less travel than a stock JK. Budget boosts are simple, easy to install, and cheap. They are also easy to sell used. Why not start there and learn over time what isn't working and then plan the next build after that.
2 door 2.5's are also 4 door 1.5's.
Im running the old 2.5 which is now sold as 4 door 2.5 and 2 door 3.5.
