Lift kit suggestios
You want a progressive rate spring and a quality shock to fix your ride. Look at MetalCloak's dual rate coil springs and Bilstein 5100 or OME shocks as an example. Longer arms won't fix the "rough" in Rough Country.
Since your driving on a lot of washboard, some remote reservoir Fox 2.0 shocks will drastically smooth out the rough off road ride having more sensitive dampening than non res shocks. I too am forced to deal with a ton of washboard where I live, running Fox 2.0 remote res shocks paired with EVO plush ride coils smooths out all the off road ride.
X2 progressive rate springs are nice. RK makes some too. Mine ride pretty good. The Fox shocks are a bit stiffer on the highway than the 5100s.
No the arms are not adjustable. They are the factory arms. Just some drop down brackets. Its a cheap setup but at the time I was anxious to get it sitting on 35's and their lift was the cheapest and said " that's a helluva deal" we'll as u can tell now I'm kicking myself in the a** and wish I would've just put up the money and did some more research in the beginning. What is your website to see the products you promote?
Former Vendor
http://www.smashboogie4x4.com/Default.asp
https://www.facebook.com/Smashboogie4x4
If you take a look at our Facebook you can see the products in action.
We are also working up the information you requested and will PM you back shortly!!
