Lift kit question about AEV 3.5
Originally Posted by Pregnant_Monk
I also just got the 3.5 AEV and if i had a choice to do it all again I would in a heart beat!!!
I've had the 3.5" sc kit on mine since May and love it. Last time I looked, the two 3.5" kits only differed with shocks, reservoir vs non. I don't beat on mine enough to justify the more expensive reservoir shocks, so I cheaped out and spent that money elsewhere. Mine is a DD and the suspension is great for that and moderate trails. I will swap my front drive shaft one day, but since I don't flex it out to the extreme, I haven't damaged the boot yet. If you disconnect your sway bar, you will want to address the driveshaft / exhaust clearance issue. I assume you 2013 has the same problem as a 2012, maybe not. Call the guys at AEV and chat. They were helpful with my questions. It has proven to be a perfect kit for my needs and looks good on 35s
good luck with your choice!
So, I am guessing you didn't need to mess with exhaust spacers. From what I have heard, if you go with anything above 2.5" lift, spacers are a must. I too am leaning towards the 3.5" AEV rather than the 2.5"; let me know if there is anything I might need to add that isn't included in the suspension package (i.e. exhaust spacers). How about gas mileage? Currently stock I am getting roughly 19 mpg; is it a major difference with the 3.5" and 35's?
As for mileage, you'll lose some because of the heavier tires. We have special (poorer) gas formulations here in Houston due to emissions. Comparisons can be difficult. I get better mileage when I fill up a couple counties away. My last around-town tank got 14. I got 17.4 on a 2600 mile run to Silverton, CO including some good mountain trails.
If I may suggest, don't think about the mileage. Get the lift and tires you like. There isn't enough difference to worry over.
Good luck
If you get the AEV lift download the instructions off the web. The directions in the box are old.
Also...read the directions it comes with too because they mention a few things not in the online directions.
With all that still be prepared to see washers mentioned and then left out sometimes and some contradicting torque numbers in the instructions vs the torque specs listed at the end of the directions. A few other things not 100% accurate.
I called them a couple weeks ago and pointed out the errors I found not sure if they fixed the instructions yet.
I like the 3.5 kit. You will need to fix the exhaust though or get a different front drive shaft. After the lift just sitting in the garage I have about .5" clearance between the two.
Also, it tried the spacers, waste of money.
Also, I tried the afe y pipe. It rubs the manual transmission mount. I called them and the said they only tested it on an auto. How stupid is that?
Haven't tried shafts. Read where some people get complaints with double cardan shafts vs the repazza.
Search some forums and yo can see photos of AEV built jeeps that show how they just add a drop down in the exhaust at a local muffler shop. I think they should sell a bolt in piece that has this in it.
Rancho also make some exhaust fix I see but I know nothing about it.
