Lift kit question
Lift kit question
I know nothing about lift kits so here is my question. I have a 2012 JKU with a TF leveling kit and 33" KM 2 tires. I was looking at the TF 2.5 lift kit and since I know nothing about lifts I was wondering if I will have to use adapters or longer shocks. I don't quite understand what backspacing and offset is but I understand using spacers on wheels is not the best idea. So will I have to use spacers on a 2.5" lift if I never plan to have larger tires.
If u get the tf 2.5", you will net 3" of lift but eventually the coils will sag back to 2.5. I had the same kit on my 12 jkur 6months ago. I also got the kit with shock extensions(which I still have mine and they are for sale) so u will need extensions or new shocks. Im still running my stock wheels with 1.5" spidertrax spacers, put 20k miles on them so far with no problems. Technically you will need new wheels with 4.5" back spacing or stock wheels with 1.5" spacers so the bolts from the sway bar links from the 2.5" lift won't stick into the side walls and your tires won't rub the frame up front while at full lock on the steering wheel
