Lift install help - can't get rear springs out?
So I'm installing (well, trying to) the rear of my AEV lift. Got everything unbolted and started lowering the axle. I've dropped the axle as far as I can w/out binding the wheel speed sensor wires and the stock springs barely budge. Is it because the Jeep isn't sitting high enough on the jack stands? I have them as high as they'll go. Is there an alternative to putting everything back together just to go buy taller ones (if that's the problem)? Maybe renting a spring compressor?
You should do one side at a time, so you jack up on side of the axle and press down on the other side, the spring should essentially just fall out, if your axle is on the ground and can move anymore you will prob need taller jackstands.
What all have you removed from rear. The speed sensors are clipped in at frame rail and behind discs. Make sure they are unclipped in both locations and also did you undo e-brake bracket. Maybe a pic if this doesn’t help. I had no issues with mine
Most lifts I've seen have you release the clips that route the speed sensor wires. Maybe 3-4 each side. Also, pull the breather tube from the axle and unbolt the rear brake line brackets.
And as Dirtman noted... Are the wheels off?
I was following the AEV instructions and they didn't mention anything about unclipping the sensor lines nor the e-brake bracket. I was going to look around to see if I could unclip them but came upstairs to you guys first.
What size springs are you installing?? Watch your brake lines and axle hose, like other said put pressure on one side and play with the spring, it should go in no prob.
The springs are the ones for the 2.5" lift, but like I said, I can't even get the damn stock ones out. Let me try unclipping the wheel speed lines really quickly, see if that gives me more play. Already undid the breather line.
Just went and looked again and I don't think it's the wheel speed sensor wires, I think it's the e-brake wires? Are those the ones that are hung by a silver bracket thing under the rear tub?
