Lift install help
Lift install help
M taking my rear shocks off and they have shock extender brackets that were on there, problem is I don't have the factory shock bolts for the top, anyone know what size the factory top bolts are??
I had to do the same with mine, don't remember the exact size off hand but the factory ones are only about an inch and a 1/4 long , just take that bolt to the hardware store get the same threads thinks it's 12 mm
Thanks, found some at autozone. The factory nuts are welded to the factory bracket, is that correct?
