lift ideas for an 07 jku
Old 04-14-2014 | 04:30 PM
  #61
rubiclone07's Avatar
I live in the coal region of pa. I don't plan on anything crazy if I did take it wheeling cashed it is my daily driver.
Old 04-14-2014 | 04:52 PM
  #62
Del Rey Customs's Avatar
Former Vendor
Aev lift will be a good option. Real nice ride for daily driving. I have the 4.5 on a JkU. Had everything in the kit. Added the C gussets to strengthen up the Dana 30 and for 3 years issue free did 5:13 gears and stock drive shafts.
Old 04-14-2014 | 04:55 PM
  #63
I already purchased a rough country 4 inch x series lift barley used for 400 bucks. I didn't know much about them I know everyone says they suck but I ran 2 on my tj and had no problems. I can't afford the expensive lifts aev would be nice to have though maybe some day.
Old 04-14-2014 | 07:20 PM
  #64
BlackRockBurner's Avatar
Default driveshafts on 4" likely
Your first post stated you did not want driveshafts, but you just bought a 4" lift for a street rig. ? Well, do more research on the can of worms that 4'" will do to your suspension geometry. Good luck.
Old 04-15-2014 | 01:46 AM
  #65
I talked to several people and they didn't have problems with driveshafts. I thought the driveshaft problems were when flexing with the sway bars off .
Old 04-15-2014 | 06:52 AM
  #66
TheDirtman's Avatar
Flexing makes that driveshafts fail faster. The angle of the driveshaft at 4" of lift will put the rubber boot in a bind and it will wear faster.
Old 04-15-2014 | 08:20 AM
  #67
So what you all are telling me is to get rid of the 4in and look for a 2.5in cause of it being a daily driver. I already have the tires. What 2.5 lift would be have the least amount of problems
Old 04-15-2014 | 08:22 AM
  #68
TheDirtman's Avatar
Learn about your suspension and what the parts do and how they interact with each other and you will answer that question for your self. The question you just asked will get you about 20 different answers and will just confuse you.
Old 04-15-2014 | 08:24 AM
  #69
suprablaski's Avatar
2.5" is your easiest solution, or pick up a driveshaft and hope whatever kit you got has the other 3-5 things you prolly really need to make the 4" work properly
Old 04-15-2014 | 08:26 AM
  #70
I am new to the jk. I had a tj before and that was completely different. So anther question is what would be a good starting point to sell the 4in rough country x-series lift with like 5000 miles on it.
Quick Reply: lift ideas for an 07 jku
