lift ideas for an 07 jku
#42
What size tires do you have now? With OD off, how many rpm's at a steady 65 mph ? Driving with overdrive off is key to the automatic and larger tires with the 3.8 and 4-speed trans.
Yes, 33's spin about 300 rpm's more than 35's at 65 mph. So, 33's will keep you in the power band while 35's will drop your rpm too low that the engine lugs.
#46
Measure your tires - don't use mfg spec.
For OD Off, divide the rpm you come up with by .69
example for a 3.8 auto:
3.21 , 31" tire (32" tire measuring 31" actual) = 1681 rpm @ 70
1681 / .69 = 2436 rpm (OD Off)
Move up to a 35" tire (34" actual) = 1533 rpm
/.69 = 2221 rpm (OD Off)
And 5.13's, which are a very popular ratio for a 3.8 auto on 35's:
= 2450 rpm @ 70 (OD On)
So with some number manipulation, you can get a fairly good idea of where you will be in various scenarios.
#48
33"x10.5" tires with zero lift. This link will answer your questions.
