Lift Help
Lift Help
So I put a TerraFlex Budget lift with the 2.5 spacers. The problem I have is the right front is sitting 1/2 lower then the left front. The stopper is 1/2 closer on right front then the left front. I have checked the spring to make sure both r seated properly and which they are. The spacers are correct and the springs are in the spacers the same. Any ideas how to fix or a way to correct , I know terra flex makes a 1/2 spacer( maybe they know of problem ) but don't know if it will work with the spacers I already have. Please help this newbie
