lift help
lift help
I'm looking at doing a teraflex leveling kit with rubi springs and shocks would I need to change anything or would it be just bolt on good to go
JK-Forum Founder
for the most part, you should be good to go. if you're running factory wheels, you may find it necessary to install wheel spacers or, relocate the rear sway bar links to the inside of the mounts as they may otherwise sit dangerously close to the sidewalls of your rear tires.
