Lift and gears
programmer
OK thanks to everyone for your reply's, Here is what I'm planning to do.
5.13's gears front and back
2-1/2" lift (coils and shocks)
17" XD addicts
Now here is my new questions for all now.
4 wheel parts is having a sale. I'm not sure which lift to get
Teraflex or Pro comp lift?
can I run this set up without a programmer?
and finally please give opinions on the following tires:
Cooper Discovery STT
Pro comp extreme A/T
Falken Wild peaks
Mickey Thompson Baja Claws
Good year Duratrac
Once again thanks for everyone's suggestions (is been enlightening)
I will post pictures of my Sahara as soon as I get everything install.
17" XD addicts
Falken Wild peaks
Good year Duratrac
Front lift: coil springs
Rear lift: coil springs
Includes: all necessary hardware
Shocks: front and rear MX6 shocks with shock boots
Max tire size: 35x12.50
Wheel size range: 16" or larger
Wheel width range: 8-9"
Min-Max backspace: 3.25-4.75"
Teraflex:
The 2.5” lift kit is an ultra simple lift kit designed for the serious no-frills four wheeling reminiscent of the old days. Build up the legend and go for a drive! The 2.5” of lift is the perfect amount to allow you to run a 35” tire, and give the maximum wheel travel and articulation. Perfect for all daily driven Wranglers. The kit is available in three configurations for your desired performance level. The basic lift includes all of the essential items needed (some form of shock modification will be required- either adapters or new longer shocks). The kit with adapters will allow you to utilize the factory shock absorbers, and the third configuration includes TeraFlex VSS 9550 shock absorbers to fine tune the suspension movements of the lifted vehicle. Pick your version, bolt it on, and get on the trail! This kit will allow you to run up to a 35” tire (aftermarket wheels with 4.5” backspacing or less are required). Fits all JK Wranglers including Rubicon and Unlimited. Will provide an average of 3” of lift on 2 door JK models. Warning: If planning to use stock wheels, wheel spacers (Part #1055000) must be purchased with this kit.
Pro Comp:
Teraflex:
Teraflex:
You are correct, there are no programmers that help with power. The AEV ProCal is the only "programmer" that works with 2011's. It still is a useful tool though. You can adjust the speedo for new tire size as well as adjust the shift points if you have an auto trans, among a few other tweaks you can make with it.
I've got an auto and when I went up to 35s I geared down to 5.13 and definitely would do it again. I feel that anything higher u would be dissatisfied and eventually gearing down further. As far as programmers go I would only purchase one for calibration and code uses because I felt no performance gains.
infO
What year is your JK? I have a 2012 with the new 3.6 and a 6 speed. With the new motor I only need 4.56 for 35". The 3.8 needed 4.88 for 35" Mine goes in next week. I cannot wait!
