Which lift is better?
So there are different brackets lifts fall into. I'm a every other weekend wheeler and use my jkur to drive to work. So out of the lower bracket which under $2000 4 inch lift would you trust. I need opinions from lots of different lift owners
Do some searching on here....you will find hundreds of threads on this.
As said above, figure out what you want/need the lift to do, what tire size you want to run, and what wheel back spacing you will have. Then back into the lift that fits what you need. Unless you are going larger than 37" tires, you don't need 4" of lift or the expense that goes with it.
Sponsoring Manufacturer
So far I have run three lifts, three brands, only one of them have been a 4" lift, but some of the same principles can be applied to all lifts from the company.
Rough Country - I ran their budget boost, and it was cheap. The parts we of acceptable quality, but you definitely get what you pay for. Braketry will hold up to DD, but off-road I wouldn't expect it to hold up for long.
TeraFlex - Their service before and after the sale was some of the best. Their suspensions flex a lot, however in my opinion I felt the springs from their 2.5" spring lift were a bit soft. I tend to go off-road with a few people and cargo in my Jeep and I always seemed to be riding the bumpstops. The TeraFlex bracketry is high quality and should last a long time. The only thing I am not a huge fan of on some of their lifts is addingt he plastic cup to the bump stop spacer.
AEV - Their suspension rides a lot firmer than the TeraFlex suspension. The brackets aren't quite as beefy as TeraFlex, but I have yet to have any issues with them. Overall street ride is one of the best, and I am able to travel the same washboard roads and trails faster than I was with any other lift I have owned.
In my opinion there isn't a one size fits all lift, and it is all about finding the one that meets both your budget, and your expectations. The best thing you can do is to find a local Jeep club and ride/drive several lifts and see what feels best to you.
Rancho Suspension: SPRING PROMOTION
Lifts are all a matter of intened use, tire size, budget, and most of all opinion. With that being said my opinion is a Rustys Lift is hard to beat in all categories. You get an excellent product, excellent customer service, excellent support & warranty, and most of all it is AMERICAN MADE.( At least thats what they tell me!)
Some other great lifts I have had experience with are; Teraflex and Rock Krawler. They both produce a great product but the BUDGET usually plays a big role with these 2 companies! I would definately stay away from any lifts that use brackets that bolt onto brackets. All they do is bandaid a problem instead of fixing them. I always prefer removing a weak bracket and welding on a new HD one! Usually these brackets are used to address the weak Trackbar brackets.
Open and read the two threads stuck to the top of this modified area.
Get an idea of what problems you can expect with a 4" lift.
Learn what all of the various components do, and which components you are likely to want to fix those problems. (caster will be off and the ride will be flighty. Do you want Cam Bolts, brackets, fixed arms or adjustable arms? Will you want steering correction? If so, drop pitman or a drag link flip? What are your plans for if(when) you lose a driveshaft? etc, etc.)
Rather than random people suggesting 50 different lifts, start with the basics of what the components do, why you might want one type vs another type, at what height you might want them, etc.
And THEN start looking at specific lifts and narrowing your choices.
