Which Lift?
I can really use some help from those of you who really know your suspension, I have done some research, but have to confess I am not a wiz at "car stuff."
I have a new 2010 Rescue Green Unlimited Sport that I am purchasing. It will be my daily driver and something I can go off roading in like in Big Bend, etc. I will not be doing any hard core rock crawling.
I am having a variety of things added to the vehicle.
One is going with 35" tires. The dealership had done a 2" body lift before I found the vehicle. I am adding Smittybuilt bumpers (front and rear w/ swing arm) and a Smittybuilt winch. I would like to add more lift and basic choice is either 4" Skyjacker lift (which I can tell Skyjacker is not highly regarded on here) or 2.5 Teraflex lift with shocks (from reading I can tell people prefer the TeraFlex lifts).
Is the choice obvious due to quality and how will driving be with these kits? Any suggestions, thoughts, critiques?
I have to decide tomorrow.
Thanks,
Lee
Thanks,
Lee
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
You're sure it's a body lift and not a spacer or coil lift? Asking just because I don't recall ever seeing any posts about dealer installed body lifts...
6" is a ton of lift for 35's. Do you have plans for 37's or bigger? If not, the TF 2.5 would be the better choice. Those TF coils will give a bit over 3" on your 4door, so will still end up with plenty of room. Another consideration is your driveshafts. I assume you are in a rush because the dealer will be installing so you can keep your 'warranty'? Be sure to not only get it in writing, but to specifically ask if they will be replacing your driveshafts when they go out.
My opinion, get the TF, chop your flares, and tell them to take the BL off. Or skip the coils, keep the BL, and chop your flares.
If you do decide on 6 inches of lift and 37's, remember that you have a D30 up front, and will need to strengthen it. And add the driveshafts at some point. And adj arms for each new shaft. And...
Former Vendor
Absolutely, stay with a 2.5" suspension system. If you loose the body lift, you can jump to a 3.5" suspension system, but that is all you need. If you combine a 4" suspension lift and 2" body lift, it will look crazy on only 35's. If you get a chance, check out our 2.5" Stock Mod, or 2.5" Max. Travel Systems. They might fit what you are looking for very well.
Rock Krawler
Rock Krawler
It appears I also need to have it regeared to 5.13. Sounds like the 2.5 is the right height and the salesman said "body lift" so I will ask further on this. My friend is the financial manager over 10 different dealerships so he is working with me on this.
So the driveshaft is an issue for the 4 dr? I thought I remember reading that was mainly on the 2dr? What kind of cost for the drive shaft?
https://www.jk-forum.com/forums/show...ery-Newbie-Has
Total lift height (from coils/spacers, not BL)
Disconnected or not
Which transmission
2door or 4door
Axles centered or not
Longer travel shocks, or shorter shocks
Driving habits (all on-road, some light trails, max flex in the rocks)
etc
In general,
2doors have more issues with the rear shaft than 4doors.
Auto's have more issues with the front shaft than manuals.
People are getting front boot/tcase contact with as little as 2.5".
The steeper angles from the lift cause the joints at the tcase to pinch, and eventually wear through. (some are over 4" and have no issues. I lost my front 4door shaft with roughly the height of those TF2.5 coils. And some are losing shafts with less lift. Just depends...
Factor in all of the above, then make a guess about your specific build.
![eek 2](https://www.jk-forum.com/forums/images/smilies/sSc_eek2.gif)
But as noted above, ask them what their policy is. If you lose a shaft due to the lift, it 'should' be covered. The downside is that you will keep breaking them.
![Bleh](https://www.jk-forum.com/forums/images/smilies/bleh.gif)
