Leveling kit & spacers?
I have a 2 door with 33 inch duratracs on a 2 inch skyjacker lift. I want spacers to widen my stance a little bit, but I am not sure what size. I don't want them to far out. And I was wondering if there is a good way to level my jeep with the lift already there. Just an inch or less in the front.
I don't think you need spacers with that setup. Are you rubbing? (you shouldn't be) Spacers are somewhat dangerous depending on how they're installed. I'd look into spending a few $100 more and just getting wheels with correct back spacing.
And you can level out your front rake by getting 3/4 inch spacers to stuff under your front coils
I have a little rub on full turn but thats it, I wasn't sure if i should go with spacers because of the said risks.
How hard is it to install the 3/4 inch leveling spacers?
As for leveling out the front end, yes - just adding a short 1/2" - 3/4" puck on your front springs will help out.
Originally Posted by Merlin4979
I'd tend to disagree with this. If you follow the steps in the Project-JK Wheel Spacer write-up, installing a set of quality spacers, like the 1-1/2" Spidertrax ones, (NOT the sandwich style ones at your local auto parts store!) is perfectly safe. If you are on stock wheels (like I am, and many others around here are) they are a great and inexpensive way to get your tires a bit further out to keep them from rubbing. I've put around 30,000 miles on mine without any issues whatsoever. Just make sure you check the torque and use Red Loctite.
The thing is you are adding an extra piece between the hub and the wheel - one more thing that could fail. Tire stores cringe at the very mention of them, probably for good reason.
A complete set of spidertrax spacers is $200. For around $400 you can get 4.5 or 4.25 backspaced black steelie wheels (cragars or black rocks). Not a big leap, and no need to keep accommodating those stock wheels.
Anyway to each their own for sure. I just don't want to chance spacers failing on me so that was my choice.
As far as spacer installs, there are a few threads on that in this forum. But you need hand tools, two 3 ton jacks, jack stands and preferably spring compressors. Not terribly hard to do but give yourself a lot of time.
I thought there would be some who'd disagree with me on this since there a lot of people who run spacers.
