Level advice help!
Level advice help!
I am currently running 285 70 17 duratracs with mt classis 2 17x9. I cant stand thr factory rake so do i go with the teraflex 2 in the front 1 in the rear or should i just get a coil spacer for the front only. I dont do any offroading.
I would go with the teraflex leveling kit. That's what I run. I love it. I also installed Monroe reflex monotube shocks and the ride with this combo is fantastic. Im 100 percent happy.
If you're happy with the height, all you really need is the spacer up front, but I'd personally do both. After a week you won't even notice it, and you won't have to worry about running if you load down your Jeep.
I would go with a front spacer first and see if it levels out before doing the rear. Might wind back to where you started...
You will be fine with the teraflex leveling kit, its made to level out the Jeep with all spacers in. just gives you a little better stance with the rear spacers and 2 inch up front.
