Let's discuss putting on some headers
I am going to put a custom exhaust on and I need some feedback from some veteran wrench heads on what would be the ultimate system for performance. I want to run headers and go all the way back w/under the cab muffler and maybe exit before the rear wheel. What do you think?
I'm no expert, but my first concern would be turning the pipes out before the rear wheel. When going over an obstacle how are you going to prevent the pipe from being sandwiched by the obstacle and frame?
I don't really see why coming out before the rear tires would be exposing them to damage more so than in the back where it is now. Even being high centered is not much of a threat being tucked up close to the pinch seam before the back wheel. It would be like you'd have to be sliding on a block of cement to get back in there. Or it would have to be sticking out pretty good to get caught on something from the side. There are some sliders out there that would accommodate making a hole through to exit the pipe and have it stick out an inch or so. Or do I have an over active imagination ? What's your thoughts ?
I'm going out with my exhaust before the rear axle as well; i've already made my custom elbows for an over the frame and out through the rocker guard. THis way you will be out of harms way, the exhaust tip will be flush with the rocker guard. There will require some internal body modifications though but with no problem!
Last edited by wayoflife; 03-03-2008 at 12:47 PM. Reason: black listed manufacturer
I had a custom exhaust on my 95YJ and had it dump before the rear axle..It was a mean sound'n freeflow'n system..Unfortunately the "Fuz" thought it was bada$$ too and just had to pull me over.. He noticed that it didn't exit the rear of the vehicle which is a "no no" in the state of MD. So if your state is cool unlike mine..then yeah go with the output before the rear wheels.
I'd still like to see some dyno sheets though.
