Lead Weights vs Equal ( dry polymer tire balancer)
I have heard of the pellets but Im in favor of the lead or zinc rim weights. I had the tire shop tell me that the large tires were very difficult to balance so I took the JK to my Jeep dealer and had them do a static balance and place the weight on the side of the rim towards the vehicle and it fixed the balance problem at all speeds.
Here is a demo of how they work, looks pretty interesting.
Anyone using them?
http://www.youtube.com/watch?v=eq263AYgyYg
Anyone using them?
I know several guys using the airsoft pellets and they love them. There is a formula that I cant recall right now to figure out how much to put in. I would never use equal, and if a shop put it inside my tires I would be pissed. What will moisture do to it in the long run? Why not just use product meant for that purpose. Anyway, I've thought about using the pellets in mine, but have had really good luck with balancing this set. So, havent messed with it...
They DynaBeads brand ones are available for off road tires. They are larger pellets, and they are made of ceramic so they won't rust or anything like that. Not too expensive either. I am going to be doing more research, but I like the idea.
Wheel weights are ugly, plus these never need to be re-ballanced like you would with traditional lead weights. Plus lead is not a good thing to be using anyway.
There's also a disc that you place behind the wheels. It's 1/8" thick:
http://www. centramatic.com/balancer.html
I actually really like the idea of the beads, they are inexpensive and you are not adding something to the Jeep that could have the chance of getting broken. I could see one of those discs getting cracked on a rock.
They don't make one for a stock JK with the 5 x 5 bolt pattern that will fit either the 16 or 17" rims. The stock TJ uses a different bolt pattern and Dana 60's do as well, I don't know what they make for those, but nothing for the JK that I could find.
They say the 5x5 for 17-inch wheels will come out by March 09. I know, the waiting game again... Unless they receive many emails from JK owners...
I used the sand bags in my old YJ. The 35 inch TSL/SX swampers were going to take a ridiculous amount of lead to balance. The sand bags worked very well. The ones I used were not designed to break open. I was somewhat worried about trapped air moisture in the tires causing the bags/water to freeze. This was not an issue.
When I get new tires, I will definitely use the sand bag route again. No lead weights to knock off when playing on the rocks!
