LCOG Suspension Set up
It depends on how much weight on the bumpers. Even JKS 2 inch is going to get ya more than 2.5- 140 lb ft/inch if running 0-75 lbs. OME 2.25 light will be lower. Check out the ARB application guide for exact rates. To keep it close to 1.75-2.0 inches, an OEM spring "swap," is the best option, and fine tuning with an ACOS or single puck.
I prefer the OME stuff it is a little more expensive but it is well built. I had their 3.5 lift heavy duty springs and shocks with the RK rear track bar reloc bracket, adjustable front track bar,JKS quick discos and I had heavy front and rear bumpers at least 100 lbs a piece plus a winch in the front plus my sliders weighed in at 85lbs a piece I built and weighed all these parts and the OME stuff still lifted the JEEP a little over 3" and rode better than stock and performed great off-road
