KM2 owners
#31
BFG KM2's seem to run smaller than any other tire on the market.If they would measure out closer to what it says on the side wall things would be different.35's measuring closer to 33's,37's measuring closer to 35's are a big deal.My Falken's are a very close to a true 37.I loved my KM2's awesome all around especially in deep snow
#32
I think most understand that a tire will not actually measure what is on the sidewall when mounted. The difference here is most tires only loose about 0.5-0.75". The KM2s start out with this under-size and once mounted are often 1-1.5" under the advertised diameter.
For me this isn't a deal breaker and I think they are pretty good tires. But for some is could be.
#33
You're comparing apples to a hammer. The complaint is about the "inch" sized tires not holding up to their specified diameter (even unmounted). It also helps that both the tires you listed are "E" rated tires that would have less sidewall deflection. I think most understand that a tire will not actually measure what is on the sidewall when mounted. The difference here is most tires only loose about 0.5-0.75". The KM2s start out with this under-size and once mounted are often 1-1.5" under the advertised diameter. For me this isn't a deal breaker and I think they are pretty good tires. But for some is could be.
#34
What the heck?! I don't care what a tire measures out at sitting in a warehouse.... It only matters once they're aired up and rolling down the highway . KM2's are a good tire but they're about the smallest rubbers on the market
#35
There are too many variables. If you have a heavy rig and are aired down to say, 10PSI, ANY 37's are going to measure probably 34 or less. Does that mean they are undersized and should be called a 34? Well no.
To me, whatever a tire measures when mounted on a rim with no vehicle weight on them is a true tire size. Otherwise, factoring in vehicle weight and air pressure just involves too many variables.
