Kc Lights Winshield Install
Just finished the Install, works great and I will set the beam angle tonight at dark. I got the Warrior Brackets from "Trailmaster"..... I'm very impressed the look it gives the Winshield.
Drilled the correct size hole in dash and mounted the switch, On/Off Switch looks Factory....
[IMG][/IMG]
I removed the Driver side panel and did all my wire hookup to the Switch through that access.
[IMG][/IMG]
A few of them mounted & working great(very Powerfull Beams) Turned on.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Very nice looking the only suggestion I'd make is to wire loom the wiring coming from the back of the lights into the wiper cowl. It'll give it a cleaner install look.
Looks good Nam. I would also suggest covering the wires with a loom of some sort not only for the looks, but to help protect the wires.
Is that your nicely painted Ford in the background?
Looks good Nam. I would also suggest covering the wires with a loom of some sort not only for the looks, but to help protect the wires. "](DONE!) [/SIZE]Covered them earlier with loom, looks much much better.
Thx, I really like the look.....
No! you can not fold windshield down with these mounted.....
Nice
I ordered the same lights only in black they are due here on the 8th I havent ordered the brackets yet I have been looking at them I might make in the shop this week, if not I will order a set. I have been laying out a set of half doors right now 3/8" aluminum plate then get the same paint code and paint them and clear coat to match.
Very little left & right field of view blocked,...just come from a normal every Sunday "JK" ride and totally used to them now. Wife even got used to them,...she would definitely be out-spoken about her view if they bothered her.
