is a K&N air filter worth it?
Old 08-21-2012, 06:27 PM
Trauma's Avatar
Default is a K&N air filter worth it?
Pretty steep at 4x the cost of fram/3x the cost of puralator paper filters.
is it just a ripoff?
Old 08-21-2012, 06:31 PM
robsjeep9's Avatar
I'm torn one of my first mods on my 09 JKU didn't notice any improvement ..... You have to maintain them be careful of over spraying them/lube with the cleaner ..... I bought the K&N cleaner kit....... Think I'm switching back to paper and replacing them more often or at least when needed.
Old 08-21-2012, 06:32 PM
Blakspire's Avatar
I've run them in everything i've owned that had an engine. Initially they are more expensive, but they flow more air, filter better, and last as long as the vehicle, with an occasional cleaning. You will probably not notice a performance increase.
Old 08-21-2012, 07:27 PM
Absolute's Avatar
I'm not a fan of K&n after I found dust post filter.
Trauma's Avatar
If i went with paper, what brand do you folks recommend?
Old 08-21-2012, 07:31 PM
xXxdirtydxXx's Avatar
Did the k&n and can't really tell a difference.
Old 08-21-2012, 07:55 PM
Delux2769's Avatar
I found the K&N filter has paid for itself now. You buy one, then you're set for life. With the other filters you need to change them out, this one, just clean and stick back in. I did notice my Jeep idled ALOT smoother after changing filter and cleaning TB.
For MPG wise, i routinely get 20-24mpg mixed driving. I've got a 2.5" lift, stock tires, k&n air filter.
Old 08-21-2012, 08:38 PM
Trauma's Avatar
20-25 wtf is your secret? I get 16, 90% highway at <70mph.
Old 08-21-2012, 10:26 PM
Tycho's Avatar
I put a K&N filter in to try and compensate for my snorkel and Donaldson pre filter seems to be doing the job.
Old 08-21-2012, 11:09 PM
SWRUBI's Avatar
What's the Donaldson pre-filter? Can you post up a picture?
Quick Reply: is a K&N air filter worth it?
