JW Speaker Evo 2 vs Trucklites
I have owned both. I sold the JW EVO 2 lights before I ever installed them after seeing them on a friend's rig. I already had truck lights and decided to keep them. That and the JW look dosent fit my jeep. The high beam on the truck lights is superior.
The beam pattern from the new ones are the same, just they redsigned the housing for their little funny/dumb DRL ring. very mall crawler if you ask me. The truck lite high beams are better than any others I have seen yet. even though certain peoples little light meters say other wise. That's because they get in the big blob of light the JW throws down and theres nothing to the sides.
Before deciding between the two. I would strongly encourage you to consider going into the vendor's thread and look at the new Trail-Flames by Ignite. Very similar to JWs in appearance. However, these are DOT/SAE, anti-flicker, no codes thrown, best light output pattern I have seen to date and half the price. Also DRL(white) and secondary turn signal (in amber) options built in.
The signal light function is pretty cool, but the beam pattern is very JW ish, and the truck lite puts out a more even beam and highbeam from the truck lite is better as well.
I currently have the Trucklite headlights on my rig. Would the JW Speaker 8700 Evo 2 headlights be much of an upgrade? How do they compare? I was looking at the Northridge4x4 sale, which is a pretty big discount on the JW Speakers from what I can tell.
IN other words, is there a significant enough difference to justify swapping them out?
Thanks.
Thanks.
I think you already got the better headlights.
You have --
More even light spread than any other option.
Wider light spread than the JW, AND a sharper cutoff, which means you can aim the TruckLite farther without blinding on-coming traffic, AND have a wider light spread at that longer distance (increased chance to see an animal eyes glare at the road side).
You don't lose the low light when switching to high.
The KC doesn't get near the evenness of the TruckLite.
The illuminated area is full of bright and dark areas, with a disturbing hot spot --
Thanks for that info. Yeah I was thinking of changing my head lights also. I have trucklites. I like them. I wanted to change them out because I want jw taillights. But now don't think it will be worth it.
