Just ordered my RC lift, any install tips?
So I ordered my lift from Rough Country on Thursday (Thanks Ben). I got the 2.5 coils with 2.2 shocks. This will be my first lift install. What advice can you pass along to make shorten my learning curve?
Thanks
Thanks
Me and a buddy installed mine a few weeks ago, well he installed most of it..
Jack stands are a must.. An extra person to help is a plus too.. It helps to have someone stand on the rotor and push it down when installing the springs, makes it easy to slip em right in.. Take your time and be sure to have all the required tools at ready..
I love the lift! My gas mileage isnt so great now, but 35s will do that I guess
Send it back and get a TeraFlex or OME!!!! J/K, follow the instructions and if this is your first lift install get a buddy to help (can be done alone easy if you have experience). Take your time and ask questions if you run into trouble instead of makeing a costly mistake.
I'm halfway thru installing this lift myself today (thunderstorm in the area put a big HALT on finishing the rear portion).
Prep work wise I used some bolt spray on the shocks and discos the day prior to starting, and have had no problem at a all loosening any of them thus far. I also decided to paint the springs flame red (to match the Jeep), just for fun.
A floor jack (two if possible) and creative use of your scissor jack will help you a lot. Jackstands, as said, are a must, as is chocking the wheels securely.
For added peace of mind, I put the tires underneath the frame as far forward as possible but giving me working room, just in case something happened with the jacks.
The front shock uppers have 16mm nuts on the top, with a 5/8" nut underneath (the one you hold onto to loosen the 16mm). When you put the 2.2 shocks on, you have a 9/16" nut on top...took me a bit to figure out something was different up there
All in all, a fairly easy install so far, I'm taking extra time to ensure I'm doing it correctly (lots of coming back to the computer and double checking other's write ups). Hopefully the rear will go as smoothly, can't wait for this rain to stop!!
The front looks awesome, definitely LIFTED!! Will let you know how the rest goes and post pics later on tonite (hopefully!) or tomorrow (if the rain doesn't stop today).
Browse the write-up that NebRedrocker did. It has pics and everything. You can find it in the Suspension Write-ups area, it'll be the one with the title "Rough Country 2 1/2" lift w/RCX 2.2 shocks install"
I'm running the same lift...
http://project-jk.com/jeep-jk-write-...ation-write-up
This write up is GREAT.... the pictures really helped me. I used the writeup and the installation instructions in conjunction and it wasn't bad at all..
The only thing I'd say is.. if you got the basic 4" lift from RC... don't use the cam bolts for castor settings... WAIT and get a set of front upper control arms.
I could only get the caster around 3 to 4 degrees with the cam bolts and they're really flimsy... This low of a caster setting made the steering really flighty on the road. After I talked to northridge, I bought a set of Currie front upper adjustable arms... got the caster up to around 6 degrees... and VOILA! No more crazy steering problems.
OH and make sure you put in some pics before & after!
while great pics and can be helpful, was not for the coil lift, it looks like the BB puck lift with the 2.2 shocks.
Or look at any of the other lift write-ups that have the same components you are installing, regardless of whether they have the same company name stamped on them. It is the pics and the steps and the commentary of any problems/resolutions that help...
And browse this one also:
http://project-jk.com/jeep-jk-write-...-end-alignment
