Just ordered Duratracs for stock wheels! 725/70r18. Questions inside.
Just ordered 5 new Goodyear Wrangler Duratracs at 275/70r18 for the stock Sahara wheels. Will be having them installed within the next 2-3 weeks. Did NOT order spacers... did some searching and thought that I "could be" alright, but any second opinions on anyone with these sizes on stock 18s? And as for tire pressure, what PSI is optimal for these tires at that size. They are a load "E" rating, and when I searched found answers for "C" and "D", not so much E.... From what I found, I'm looking to run them at 35psi. That too much? They will be used for daily driving - lots of highway driving, and the weekend trails. Thanks for any help.
EDIT: Photo album on page 2. Inspired Engineering cube fog lights, 275/70r18 duratracs, and spidtertraxx 1.5inch spacers!
725/70r18?? Running 58"x28.5" is going to be one badass Jeep!! Might want to get some axles off a bus or somthing?
Sorry, couldn't resist. Haha
You shouldn't have an issue. Might have to do very minor trimming of the air dam, but not an issue. 35 psi sounds a little high. Try 32-33 psi.
I would start at around 30psi and see how they feel. I have 285/70-17 E rated and find that 30psi feels great and no strange wear on both my 13 jku and 14 jkur.
Sounds good to me. Did you have any concern about the "E" load range like most people do? I'm not too sharp on what that means, but I'll take your word on it and run 30-32psi. Thanks!
ha! Didn't notice the typo... but thanks. I guess I'll try somewhere between 30-32psi after the comment below as well.
I have the duratracs in the same size. Before I got spacers I had to trim the airdam and did have some minor rubbing on the tie rod at full turn. It was livable, but I'm glad I added the spacers.
I love the look of since adding the spacers, just fills out the fenders better and gives the look it should look like from the factory.
So you can go without spacers but from my experience I would recommend getting them.
I haven't aired mine down at all yet still running whatever they set them at when installed. And it is a bit stiff with the thick E sidewall. I will be lowering the psi to see if I can smooth it out some.
Will do. I've seen a lot of scattered posts about these sized tires on stock wheels and stuff. I will try to start it's own thread with pictures of every little detail and an entire review.
I did go with 1.5 spidertrax. I hear you on spending the money. It never ends.
You won't need them, I went a while without before I decided to add them. But I don't think you'll regret it if you decide to get them down the road.
I put 275/70R17 on my stock wheels without spacers and ran them that way for a while. They would rub against the swaybar at full turn, but knowing that I was able to just adjust my driving (and parking!) habits until I got some spacers. And while the Spidertrax are great, I actually bought the Rough Country 1.5" spacers for a lot less money. I think I paid about $125 for the pair. Just installed them today, so if I end up with my wheels coming off on the highway this week I'll make sure and post an update.
