just installed 3.5" lift cant center steerig wheel
Old 06-09-2014, 05:13 PM
Invest2m4's Avatar
Originally Posted by Ncb
Sounds like loose track bar bolts. Did you use a torque wrench or just tighten the hardware?
^^^^this right here. Assuming it's a stock drag link, highly unlikely it's the cause. The track bar will cause the steering wheel to be off. Double check the track bar bolts are torqued. If it's an adjustable track bar, the jam nut needs to be torqued hard (like 200 ft lbs).
If that isn't it, pull the track bar and inspect the bolt holes to see if they are elongated.
Old 06-09-2014, 05:16 PM
Invest2m4's Avatar
Just looked the kit up. Did you install a new pitman arm?? That bolt needs to be torqued hard as well.
Old 06-09-2014, 05:31 PM
scratchkenny's Avatar
Yes stock drag link, no adjustable track bar. bolt holes look fine.
Old 06-09-2014, 05:33 PM
Yes I installed the pitman arm that came with the lift. Torqued damn hard.
Old 06-09-2014, 07:31 PM
Collyn's Avatar
Damn hard for some, is damn weak for others. Hah. Torque wrench. Use it. See if damn hard is enough.
Old 06-10-2014, 01:44 AM
Veteran: Air ForceFJOTM Winner
Mark Doiron's Avatar
Pitman Arm Shaft 185 ft-lbs.
Drag Link Ball Stud to Pitman Arm 77 ft-lbs.
Old 06-10-2014, 04:20 AM
Invest2m4's Avatar
Pitman Arm Shaft 185 ft-lbs. Drag Link Ball Stud to Pitman Arm 77 ft-lbs.
This is the only logical issue since you didn't swap anything else.
Double check you reused the lock washer above the nut. Technically, you should replace the lock washer.
Use a market and draw a fine line across the pitman arm nut and shaft. That way you can see if something might be rotating.
Torque to 185. Drive. If the steering moves, go back and see of the nut backed off. If so, loctite it.
Old 06-10-2014, 05:32 PM
Yep the washer is there, I marked the pitman arm, the drag link where you twist to adjust the steering wheel with a sharpie went for a drive when I got back check and every thing is in the same place.
Old 06-10-2014, 06:20 PM
I have a set of Rubicon rails I will give to some one that can come over to my house and give me a hand. Hampton Roads Va. area
Old 06-11-2014, 07:51 AM
Sahara Lee's Avatar
Pitman arm torque is critical. I initially torqued to about 160 ftlbs and had play. Got a 4' piece of steel tube over the arm end for hold-back and a 250 ftlb rated torque wrench. Once I got to 185 ftlbs no more play.
"If you don't have time to do it right, when will you have time to do it over?"
- John Wooden
Quick Reply: just installed 3.5" lift cant center steerig wheel
