Just got my Optima Yellow Top: Advantages of Dual?
Right now I have 4 stock fogs, the stock headlights, and two 6" kc slimlights running off of it, I plan to add a winch, one more set of lights in the front, and possibly 6 rock light like WOL, do you think it would be wise to go with the dual setup that just came out to run all of this or will the one be enough?
That said. Say you're out and are listening to the stereo all day. With duel batteries, you're not going to get stranded because you drained your battery. Dual batteries will also give you a larger amp reserve for a winch. A winch will kill a battery fast and it draws way more amps than an alternator will put out. This alone is enough reason to dump the stock battery. But even an optima can run out of juice given enough use and too short a recovery. That's why I have a battery dedicated to just starting the Jeep. It would take a lot of work to drain two Optimas with the engine still running, but when you have a winch you'd be surprised at how often it can get used in a day.
There are no down sides to running two batteries other than weight and cost. The benefits the first time you use it IMO justify both.
I'm in the process of reconfiguring the kits to have more options, making them more affordable than they've ever been. I should have pricing Monday or Tuesday.
Using a basic solenoid instead of the Smart Isolator. Drops the cost a ton. The way I'm wiring it up, it still functions similarly and satisfies the needs of 75% of the people. The Smart Isolator kit will still be available for those who like bells and whistles.
I will answer this really quick since John seems to have run off to do other things.
Smart Isolater: When the engine is running and the alternator is producing power the voltage level of the Jeep is around 14.4VDC. When the engine shuts off and the alternator is not producing power the voltage drops to 12.8VDC. Pick a voltage between those two values. 13.2VDC. When voltage goes above that the Smart Isolator connects the batteries together and both batteries charge. When the voltage drops below 13.2 the Smart Isolator seperates the batteries so the Extra battery is drained and the Engine battery is not drained. The Smart Isolator keeps the batteries seperate until the Engine battery is up to its full charge state.
Solenoid: When the key is off, it opens. Batteries are seperate. When the key is on it connects the batteries and both batteries charge together. Think of it as a dumb switch. It doesn't wait until the Engine battery is at full charge. It just connects them when the key is turned on.
