JKS & Teraflex Control Arms - Flex Arms
I noticed that JKS is a fair amount more expensive than Teraflex for the adj control arms I am looking at (Front Lowers).
Is JKS really that far ahead of Teraflex in this area - science & manufacturing quality?
What's the deal?
Thnx
What's the deal?
Thnx
You're going to get varying opinions here, but I tend to think JKS are as good as you can get. Their adjustable arms are incredibly sturdy, have a rotating design that won't bind when articulating (no jam nuts ), and use rubber bushings that make for a quiet, comfortable ride.
Gotta support my Nebraska boys; the stuff JKS makes is more art than Jeep part.
There are plenty of happy owners with the TF CAs but the JKS arms do have a unique design that allows the arms to "float" rotationally so they will not bind and damage the bushings. Furthermore, the bushings are not just rubber they are are the OE bushings which are designed to provide a good ride, long life and require no lubrication (the arm itself does require lube).
The reason I picked my TF LCA's over the JKS is because after looking at the pics, I was afraid that the edge where the C-clip is on the JKS arm would get smashed on rocks versus having a jam nut there to give a small level of protection. I just thought that if it got dented over the C-clip, it would pretty much be screwed as far as a seal goes. But, pictures can be deceiving...
Lots of TF vs. JKS threads this week. The truth is that both companies make fantastic products. I chose TF control arms and JKS track bars, but I can see the case for doing the opposite. Potato, potahto...
I have JKS track bars, and I love them. They are without a doubt a quality product.
I also have Teraflex coils, stabilizer, and spacers. They are without a doubt, quality products.
My budget will probably be the deciding factor, but I go back and forth between the two when considering which arms to eventually buy. I'd like to go with JKS, but if I can't afford it and get the TF instead, I won't regret it at all.
1) JKS uses OEM rubber bushings to prevent harsh noises from transmitting into the cabin of the vehicle where TF does not.
2) They will also freely rotate to prevent undue stress on the frame/axle brackets...Teraflex does not.
You can pay JKS now or pay them later when you need to replace the Teraflex control arms that have failed or have simply grown tired of the maintenance problems associated with them.
My setup & results of signifcant research and consultation for my lift:
1) JKS Control Arms
2) Teraflex Front Adj Trackbar - JKS Rear Adj Trackbar
3) Teraflex Rear track bar bracket - #1954777
That's quite an indictment of Tereflex's product. Is this based on your own intuition of how these things probably work, or are you basing this on evidence and experience?
