JKS Sway bar disconnects Question
When using the disconnects on an "X"...do you need to buy extended brake lines for the front to have the increased flex without tearing the lines out....basically are the Rubicon brake lines any longer than the "X"?
sorry to switch topic but why did u select the jks instead of other companies quick discos? just wondering because im getting some this week and im not sure which to get myself.
that was gonna be my next question. How well they had worked assuming you had used them already. I was reading another forum and the guy who had the JKS said they were really hard to put back together once you had disconnected them. is that true? or was it a user problem?
ok well thats good to hear then. I was afraid i was gonna have to just save and get the E-connects because i didnt want the crazy trouble this guy was describing. Thanks for the input. It was most helpful. Would you also recommend the JKS?
