JKS Rear Trackbar install
When installing a new JKS rear trackbar, do I need the JKS rear trackbar bracket also?
Background: Installing Jspec 2.5 lift kit on 2017 Rubicon Recon. Also added the front and rear control arms and the rear trackbar.
Just not sure if I use the included rear trackbar bracket with the rear adjustable trackbar.
Thanks for any help.
An adjustable trackbar centers the axle, while leaving the bar at a steeper angle (due to the lift height).
A raised rear bracket will center the axle (though not as well as an adjustable), while also helping with the angle/roll center.
So, no, you do not 'need' the bracket. But, you might find that it handles better with the bracket installed.
remo427 (08-13-2018)
The rear track bar mount has been a weak spot for many folks. Installing the bracket will help to reinforce this area.
