JKS Rear adj track bar
Old 12-08-2013, 11:06 AM
Rita Wrangler's Avatar
Default JKS Rear adj track bar
Am I supposed to use the frame side drop down bracket with the adj track bar ?
Old 12-08-2013, 11:28 AM
A'sJK's Avatar
[QUOTE="Rita Wrangler;3779371"]Am I supposed to use the frame side drop down bracket with the adj track bar ?[/QUOTE
no
Old 12-08-2013, 11:33 AM
It seems like the bend isn't in the right place and is gonna hit the axel
Old 12-08-2013, 11:36 AM
A'sJK's Avatar
are u sure u are installing the right way? mine bolted up just fine. i assume u have a basic d44 rear axle? more info on ur setup needed.
Old 12-08-2013, 11:47 AM
I think I figured out what I did wrong tried to install in frame side 1st instead if axel side 1at stupid me read instructions then didn't follow them
Old 12-08-2013, 11:54 AM
Thank you for helping
Quick Reply: JKS Rear adj track bar
