JKS Discos
JKS Discos
Ok so I finally got my JKS discos installed. After I test drove it and it rides fine on the road....
I ordered the discos for the 2.5 inch+ lift jeeps and dont have a lift. Didnt mean to but did , David told me I should be ok though. Just to make sure I disco if I do any type of offroading.
Needless to say I am about 10 degrees as opposed to the supposed 5.......... whats the deal with this degrees thing anyways?
I do plan on doing the OME lift as soon as I get the $ do I would like to keep the Discos but IF I need to I can order in the regular ones and keep the ones I have now for when I have lift,
Since I already have hte other stuff installed it should be super simple switching the links in and out(if I decided to get hte little ones)
As for zip ties these disconnects are fully removable. So, the only thing that needs to be zip tied up is the swaybar itself. Check the writeups section as I recall a thread with a picture of how to properly zip tie the sway bar so that it is level.
That is indeed interesting about the ones I ordered and the ones I got. I dont feel it to big a deal.
It may be a year or so before I lift mine though. I will go with the OME which If I remember correctly is 2.5 inch +
On another thought - I will keep a close eye on these 'longer' links and make sure everything is going ok, and if need be Ill get the shorter ones.
Since they where like 139 shipped I am not to worried if I will have to buy the shorter ones to.
Thanks for the replies so far
It's a Northridge thing. You probably did order the ones for use without the lift.
David
I actually kind of figured since you could adjust them that I was getting the stock + 2.5 inch lift
Need not fear I tested it, rides same as with stock links and I am getting an 2.5 inch OME installed sooner than I expected(hopefully order within a month), so should be alright till then
