JKS Adjustable Coil Spring Spacers
Has anyone used or have any info in these, I like the idea when I add a front bumper and winch I don't go back to the old factory rake look
http://m.quadratec.com/products/prod...?pid=16156+002
Other than the cost, the problem I have with them is the minimum lift heights - 1" front, 2" rear. So assuming a normal front rake, you are looking at around 3" up front to level it with the rear spacers at their lowest setting. And if you are ending with a 3" lift, why not go with coils and extra components for caster/axle centering/swaybar angles/brakeline extension/etc. I do like the idea of adjustable spacers though, as long as they fit into your build plan.
Thanks
