JKS adjustable coil spacer help
Hey all,
So I need some clarification on these, I'm looking to get bigger tires on my 12' JKU rubi. I priced out a 2.5" TF coil lift, but this JKS system has got my interest.
My questions are;
What do I need in addition to this kit? Track bars? Exhaust spacer? Extend brake lines or E brake?
What size tires will fit? I'd probably get a set of black crager soft 8's with 4.5" backspacing.
Is this kit DIY? I have a fair amount of tools, and fair amount of ability.
Any help is much appreciated!!!
My questions are;
Originally Posted by Hummin64
Hey all,
My questions are;
My questions are;
Thanks for the input! I heard over the weekend you can use them on the stock Rubi coil, but it's recommended to upgrade the coil. In that case, I think I will do the Coil lift first, and then consider the JKS ACOs. Another question I have is, How hard it is to adjust them, and is it difficult to get level?
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
Lower it until spring tension is released
Loosen the one Allan bolt
Then twist by hand the retaining ring to increase or decrease desired height.
