JK Unlimited Bumper
#22
the shipping weight of the bumper was 96 lbs. I can't remember for sure what the shipping weight of the winch mount was but I think it was around 36 lbs. I haven't got the skid plate yet so I don't know what it weights.
#25
Sure it can. With that much weight, the front of your Jeep can sag up to 1/2"-3/4". Add another 80-100 lbs. for a winch with steel rope and it will sag even more. If you're still sitting on a stock suspension, you'll now be sitting that much lower to the ground up front. If you have a suspension lift, you'll have just lost some of the height you paid good money to get your Jeep up higher off the ground. Of course you can add coil spacers to compensate for the extra sag but depending on how much sag you need to compensate for, you now run the risk of over compressing your coils. Last but not least, all that weight up front and up higher on your frame can and will effect the way your Jeep performs on the trail. Just think of what it would be like to go wheeling with a full grown adult standing on the front of your Jeep.
Now, this is not to say that you shouldn't go this route, just that it can and will effect performance.
#26
As I told, I have ordered the AEV bumper with winch mount and skid plate. And I’m still sitting on a stock suspension. Eventually I will want to get the Warn Power Plant winch. I have stock Rubicon Wheels with Mickey Thompson Baja MTZ 33 X 12.5 X 17 tires and SPIDERTRAX wheel spacer 1.5.
So having this in mind; what would be a good setup for my JK?
#27
#28
Actually I didn’t realize that they weren’t compatible. I would like to get the Warn Power Plant and also the AEV bumper but knowing that it can’t be, other options could work.
Which are your suggestions? Thanks for the advice.
Ahhh, a stubby could also work for me.
#30
Well, if you're willing to consider a stubby, PUREJEEP, Rock Hard 4x4 parts and Shrockworks front bumpers will work with a Warn Power Plant. If you want something in between, the LoD will work and if you want something closer to a full width bumper, the Warn or even Mopar bumper will do the trick. I'm sure there might be others as well, but these are just a handful that I know of to work.
