JK Side Armour Rock Rails - which mount prefered ?
Which method of attaching these Side Armour Rock Rails on a 4-door will take the most beating and most secured ??
The shape of the three below are very similar, double as entry steps and including shipping costs are within $50 of each other, all $250-300 a pair.
The Rugged Ridge & Smittybilt attach to the frame at the body mounts using the stock vertical bushing bolts, two per side. MYKLT8 wrote-up with pics on the Rugged Ridge ones on thread https://www.jk-forum.com/forums/show...t=31705&page=2
The JCW rails need 8 holes drilled and bolt horizontally into the frame, as ENTERIC wrote-up with pics on thread https://www.jk-forum.com/forums/show...t=33798&page=3
Rugged Ridge #1
#2 https://www.jk-forum.com/forums/atta...1&d=1206042951
Smittybilt
JCW
Rugged Ridge #1
Smittybilt
JCW
I decided to go with a different set but these were three of the originals I looked at. Here is the thread I started, hope it helps.
https://www.jk-forum.com/forums/modified-jk-tech-2/need-set-rock-rails-34807/
https://www.jk-forum.com/forums/showthread.php?t=34807
First off, what type of off-roading are you looking to do? Are you planning to use your rails as protection or as sliders (pivot points for turning on rocks)? If you're planning on normal offroad protection, then any of the three you listed will be ok (although I am NO FAN of Rugged Ridge ).
If you're looking for sliders, then ditch the three you posted and head over to Shrockworks.
I am not sure if it adds any value to your decision, but I went with the Olympic reversa-bars for the option of having a step if needed (when wife is pregnant or have family in town that needs them down). The mount was pretty good, and seems to offer as good protection as most of the other sliders.
Pics are in my gallery if you want to see them mounted on a 4-door.
