Jk running hot
So my fan gave out 2 days ago on our way down to buena vista. That caused the radiator to crack. Found the thermostat bad also.
Just got it back up and running last night. Holy cross today! We will see!!!
Northridge 4x4
Northridge 4x4
Have the same issue with my 2012 JKUR. On hills down nag 65 to 80 can get up to 250. I've had the fan and controler replaced, system flushed. Installed a Misimoto radiator. Daystar hood vents. Sprayed out everything. Runs a little cooler but still way to warm. I have sitting at home a new bumper tap hat will lower the winch out of the airflow. Hope this fixes the issue.
I'm stumped nobody has mention a fairly basic fundamental, and the main reason JKs and pretty much anything Dodge for the most part, run this hot, the fan programming temp suck. There is no need for fancy radiators, water pumps, hoods and water weeter, program the fans to come on sooner and you'll enjoy way cooler ect's.
Diablo intune or trinity can modify your fan settings.
The difference between your (OP's) and your bud's Jeeps that makes his run cooler... Probably because he is running a 6-speed so he has no trans cooler in front of the radiator. Your auto and TC are generating a lot of heat which is being rejected into the airstream that removes heat from your engine's cooling system. His radiator sees ambient (or ambient plus AC) while yours sees higher than that from the thermal energy removed from the tranny fluid added to ambient with the effect of effectively reducing the effectiveness of the radiator..
Holy cross was fantastic! Made it to Cleveland rock and had to turn around. Wondering if we were trying the wrong line.
Jeep runs cooler than ever since replacing the radiator, thermostat and fan. Still got up to 230 climbing out of Breckenridge on 70 but considering the steep climb and my total weight was probably 6000-6500 lbs I'm ok with that.
Northridge 4x4
I'm stumped nobody has mention a fairly basic fundamental, and the main reason JKs and pretty much anything Dodge for the most part, run this hot, the fan programming temp suck. There is no need for fancy radiators, water pumps, hoods and water weeter, program the fans to come on sooner and you'll enjoy way cooler ect's. Diablo intune or trinity can modify your fan settings.
Since my blowout and repair jeep seems to run about 2:15. Fan rarely goes into high anymore.
Northridge 4x4
