JK pulling to right after lift/tires...help!!
LOL!! before you spend a dime, find someone with a set of BFG MT's or AT's and ask to try them out. just take your jeep around the block or just long enough to see if it makes a difference. i can almost guarantee that it will and that spending money on all this extra stuff won't make a difference. with toyo's, a slight pull to the right is totally normal.
JK-Forum Founder
FWIW, i just swapped in a set of falken at's on my orange JK and, without changing a thing to the suspension, the pull went away
i've been running toyos for years and they will not put any unnecessary wear on your jeep. like everyone who has them, i too have a slight pull to the right.
[QUOTE=bubba_zenetti;1945985]Increase the caster on the right side by 1 degree will usually get rid of most of it.
How did you get the solid front axle to twist enough to change the castor on the right without changing it on the left as well? I tried that until I realized I wasn't going to twist the axle, which has to happen to accomplish it. Two alignment shops tried that until I asked them the same question. They agreed. It's possible to do it with an independant axle, but not, to my knowlege, on a solid axle.
WOL may be right, regarding trying different tires. Sometimes, that's all it takes. However, I rotated the stock tires and the new MTRs and the pull didn't stop until I pushed the right side forward with the adjustable arms. The PSC addition corrected the rest of it only because the ram has pressure to hold it straight.
[QUOTE=Crasher;1946373]
you have to have adjustable front lower control arms to adjust your caster
[QUOTE=Pluke the 2;1946389]Yes, I know. I have upper and lower adjustables up front. I was saying that I don't see how you can change the castor on one side of a solid axle and not affect the other. To my knowledge, it can't be done.
ok guys i'm back...will post a pic when i get time to scan it in, but i am at work. so here goes.
got an alignment and tires/wheels balanced today because of a high speed shimmy at 65-70mph. JK is still pulling to the right but no real big deal to me. however, my thrust angle for the rear is -0.30 and the alignment guy asked if it had been wrecked or if it pulls to the right (he doesnt work with ORVs often). i have the rancho 4in sport lift with trackbar brackets front and rear
