JK PSC hydro assist install help
Just installed psc hydro assist components and getting ready to hook-up ram lines to the steering box. The ram is installed in a "standard" orientation fixed at axle side track bar mount with pushing/pulling towards center of tie rod. Is hooking the lines up correctly as simple as box port closes to passenger side line ran to the passenger side port on the ram, and of course the same idea for driverside port? Please send a pic of your lines if possible! Thanks for the help...
Do you have the PSC steering box or did you tap your own?
Regardless, there are two easy options for you. 1) Call PSC and ask. 2) Hook the lines up, disconnect the ram from the tie rod end and turn the wheel a little and see if the ram goes the correct direction. If it doesn't, then swap them and you are good to go.
I just installed the PSC kit on my JK.I have the PSC steering box and the port closest to the firewall on the box went to the passenger side of the ram,also PSC has great customer support
Agree!!! PSC has been great... Yes complete kit with PSC gear box... Like the advise on initially disconnecting the ran to ensure proper proper flow, just would like the hydraulic likes hooked up correctly to start. Ok, so port closes to firewall to port on passenger side ram. Thanks!!!
