JK owners experiencing pinging with their Superchips tunes
#32
I work long hours, so I wont be able to open a service call until Friday.
My FP serial # is 1477070
I have been having knocking for about 2 months. It happens above 3k RPM.
I am running the 87 octane tune with 89 octane gas and still have some knocking.
The only engine mods I have are a drop in high flow filter and NGK sparkplugs.
If I was running a Megasquirt on my Jeep I would start by pulling 2* of timing above 60KPA of manifold pressure.
I don’t know how advanced the factory ECU is on the JK, but most are set up to start pulling timing after a set number of cycles while sensing knock. Maybe it is not very aggressive, or maybe we have already exceeded the amount of timing the ECU can pull.
One question: Does the towing tune have less spark advance in the higher RPMs?
#33
Crawl setting
I know that ths does not pertain to the pinging thread, but I would like to know if I set my jeep for the Crawl setting, would there be any problems if I drove it in 2 wheel drive or 4 high? Some of the trail heads are a few miles away from the airdown areas in which I would be driving on hardball roads vice soft sand/dirt.
#34
X2 here... Just awesome to see a Manufacturer being proactive and not hiding under a rock at the first sign of something possibly not being right. Kudo's to Superchips. I hope everything works out to all involved.
#35
Add me to list of users that are having issues with pinging/knocking. I didnt have an issue for almost 2 months, a cpl of days ago I updated so that I could get the option to have the stock/moderate/superchips pedal option. Ever since then i've been getting the pinging/knocking even using 89 octane with 87 tune, so i've set the JK back to stock for now. I'll try re-programming and using the Superchips pedal map as opposed to the moderate to see if it makes a difference and just until I can burn the almost full tank of 89 octane I have then revert back to stock, anyone noticed if we can change tire size without being tuned?
#37
Mine was pinging on the 87 tune using 87 octane in Dallas. I switched to 89 octane gas and it went away. Last week I moved to Colorado and now live at an elevation of 7700'. It pings under heavy throttle with the 87 tune even with the local "premium" 91 octane. I returned it to stock today, so I may just sell the unit I guess.
#38
Any 93 octane available you can try?
And when was the last time you updated your device over the Internet?
#39
#40
