JK owners experiencing pinging with their Superchips tunes
#101
I live in delaware so it's low elevation but has hills and curves when driving. I loaded my SC this past Saturday with the 87 tune and had pinging. Since then I returned the Jeep to stock, double checked the Software was updated, then Tuned again with 87. I took it easy until I burned a 1/4 tank of gas and then did some nice skinny pedal smash tests and had no pinging. I had the RPMs up to red line and still nothing. I drove around a lot and burned the tank to empty and filled her up with 93 octane today in the morning and loaded the 93 octane tune. Took it easy on my way to work (around 50 miles) then on the way home did the same type of tests. Still no pinging and the 93 tune felt good. I was able to stay in 5th/ 6th longer without down shifting on I95. Next tune will me the Tow. Home that helps. Bottom line, returning to stock then tuning again worked for me.
FYI- 2010 Sport 2 door, 6 speed manual, 35'' tires, stock 3.73 gears.
#103
To help out Superchips and to maybe solve this a little faster can everyone please copy and paste the questions and fill in their answers. This is for Jeeps that are using Superchips Flashpaq with ping AND those that do not.
Ping or no Ping:
Flashpaq Serial number:
Flashpaq last updated - when:
Ping Confirmed with Data Acquisition (knock retard):
2 door or 4 door:
Hard top or Soft Top:
Rubicon or Standard:
Auto or manual:
Tyres:
Wheel size:
Gears:
Bumpers (front and rear):
Lift:
Any other weight added to vehicle:
Engine Mods:
Electrical Mods:
Where you live:
Where you live Elevation above sea level:
Where you live ambient temp:
TUNE NOTES (Copy and paste this again if you have tried several tunes)
Tune:
Miles on the tune:
Octane Rating of fuel (RON OR MON - If Known:
RPM of Ping:
Throttle Position of Ping:
Vehicle Speed of Ping:
Ping or no Ping:
2 door or 4 door:
Auto or manual:
Tyres:
Wheel size:
Gears:
Lift:
Engine Mods:
Electrical Mods:
Where you live:
Tune:
Miles on the tune:
RPM of Ping:
#104
Ping or no Ping: PING
Flashpaq Serial number: 1514860
Flashpaq last updated - when: 3 AUG 2010
Ping Confirmed with Data Acquisition (knock retard): YES
2 door or 4 door: 4DR
Hard top or Soft Top: HARD TOP
Rubicon or Standard: RUBICON
Auto or manual: AUTO
Tyres: 285 70 r17
Wheel size: 17x8.5
Gears: STANDARD
Bumpers (front and rear): SATNDARD
Lift: 1.5" Teraflex Levelling Kit
Any other weight added to vehicle: NO
Engine Mods: NONE
Electrical Mods: BATTERY OPTIMA D34, ARB COMPRESSOR
Where you live: WESTERN AUSTRALIA
Where you live Elevation above sea level: APPROX 50ft
Where you live ambient temp: 25Deg CELSIUS
Tune: 93 Tune
Miles on the tune: less than 10kms
Octane Rating of fuel (RON OR MON - If Known: 98 RON (93MON)
RPM of Ping: 2000+ all through the range (constant ping any RPM). Most evident upon down shift.
Throttle Position of Ping: ANY
Vehicle Speed of Ping: LOW SPEEDS LESS THAN 50KM/h
Tune: 91 Tune
Tune: 87 Tune
RPM of Ping: ~4500+
Throttle Position of Ping: WOT (Wide Open Throttle)
Vehicle Speed of Ping: Less than 100Km/h
Tyres: 285 70 r17
Wheel size: 17x8.5
Gears: STANDARD
Engine Mods: NONE
Tune: 93 Tune
Tune: 91 Tune
Tune: 87 Tune
RPM of Ping: ~4500+
#105
#107
Sponsoring Manufacturer
Superchips Representative
#108
#110
