JK overheating
All right, I have a 2013 JK Unlimited lifted 3.5 with 35’s and its an automatic. I’ve been having an overheating issue when driving on the freeway only when under a load such as gunning it to pass a car or going up hill. Temp will rise to the mid point of between middle to high. Thermostat has been replaced, coolant flushed with no luck. Not eating thru coolant either. I did have a code pop up on my tranny for the torque converter and started feeling a sluggish feeling. Will the torque converter cause this? I wouldn’t think so. Next step is to replace water pump as I’m up to 118k miles.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
You don't have a programmer/tuner that reads the actual coolant temp? Something as simple as Jscan app with a OBDII dongle ($35 total) is really handy to have. That needle is just not a great representation of actual temp. You're 100% certain you have that cooling system bled really well? Sometimes that's kind of a pain on our JKs. Have you regeared? Just curious what kind of RPMs your running. Getting into the fall I'd think temps out in AZ aren't 95*+ anymore right? Here in DFW things have gotten much more mild with summer temps falling off. Seems odd to be having the issue now vs. dead of summer, so I'm thinking this isn't just a flat out ambient temp issue like I was seeing in 100*+ here. I recently replaced my radiator and swapped the WP out while I had everything apart. It's a bit of a pain to get to on this 3.6L as the alternator and pullies have to come off. If you do change your WP, I'd be really curious to hear if yours looked anything like mine inside the gasket. Take a look at my pictures in this link -
https://www.jk-forum.com/forums/stoc...nstall-354457/
I'm by no means saying that was causing an issue for me, or that you have a WP issue, I just don't have much explanation for the pitting in my gasket.
You're not noticing coolant level in your resi dropping at all right? When you open that rad cap in the morning it's topped off as it should be?
![](https://www.jk-forum.com/forums/images/ranks/veteran_nationalguard.png)
Do you have CEL light ON. Check for Codes.. A torque converter / Trans issue could contribute.. Is this occurring when the AC or Defrost is on; these ON should have the fans ON. Could be a sending unit malfunction and FYI when I had the thermostat replaced it took 5 burp sessions of the system over 4 days to get all the air out.. a quick check of the bottom rad hose -- squeeze and if you have air pockets you will know -- it will not be firm.. the top hose will probably be collapsed when COLD.
2013 jk 3.6
33s steel wheel
Steel fender
Stinger bumper
Roofnest
So I have weight
my jeep has been overheating in a similar way. I have replaced 2 thermostats, radiator, water pump ,blown oil cooler and several flushes. I still overheat on small hill climbs when I go into 3rd or lower for the climb. Getting on the hwy in the summer can even be a huge issue cooking. Im getting hood vents soon. While in moab I popped the hood before arches Park climb on the payment. Placed a 4x4 block of wood to keep it open and I never cooked once climbing in 3rd. It can't be that stupid simple and I hope thats all i need is air.. Im also digging on the net and although It dont add up. Transmission and torque converter issues. Im considering a tran cooler upgrade. Im learning as I go but I know the trany temp shouldn't reflect on the engine temp. But at this point its a ghost and its only when im climbing. Parked I never heat heat up while running the jeep. Slow crawling going easy I never heat up. Its once im rolling and trying to keep speed it begins to cook.
I run into others and the all claim vent vent vent
33s steel wheel
Steel fender
Stinger bumper
Roofnest
So I have weight
You're talking about that seal that just sits on top of the grill and is visible when the hood is down? Interesting. I don't think I've ever seen someone comment about that one before.
Do you by chance have a winch mounted to your front bumper? Some of the bulkier winches have been known to affect the cooling, although I have never heard of one overheating because of this..
