Jk Hemi swap radiator options (still in production)
Seems like some companies have stopped making radiator options for the JK Hemi swaps. Which companies are still offering options (that don't leak) and have they successfully fixed the ongoing issues? Anyone tried the Entropy option??
I don't think you need a made for Hemi swap radiator. I just got done doing a Hemi swap and I'm using the stock JK 3.8L rad and fan. I've only driven it in winter, so I don't know if cooling will be an issue in the summer heat.
Are you actually having over heating issues?
Sixty4x4 (01-10-2023)
https://www.jk-forum.com/forums/modi...1/#post4396938
I didn't use a kit. I got the bolt-in mounts from JSS and harness and computer from Hot Wire Auto,
and made everything else necessary to make it all work. Which wasn't much to speak of. The exhaust was the only real PITA part.
Engine and transmission are from a 2006 commander, so it already had the right type of timing cover and belt driven accessories to fit in the JK. Its the 5.7L and 545 REF.
Just to echo what Junkyardjunkie said - I run a 3.8 stock rad with my Chev LT conversion and yes the HP is quite a bit down on what the 6.4 puts out but I use a Camaro 2018SS fan that is infinitely variable and temps never rise above 90C or 205F even wheeling slow on steep hills on a 95-100Fday. The secret is the fan and keeping all of the shrouds sealed so that the air pulled by the fan has to go through the radiator not bypass it. Those 5.7/6.4s are just not going to work hard enough in a Jeep to heat up a lot.
Yeah im using the OE 3.8 fan and have never had cooling issues even in the middle of summer in 4LO most the day. Mind you the fan pretty much runs constantly on low speed but has never required hi speed. I keep a spare fan on trips just in case
