JK Heavy Duty Crossmember
Old 12-17-2015, 06:40 PM
jadmt's Avatar
Originally Posted by Rebar-7
good deal , so it uses the stock fasteners
Were it bolts to frame brackets then.
yes it reuses all stock fasteners. has welded nuts just like stock for tranny mount and stock bolts nuts to frame. plug and play.
Old 12-18-2015, 02:13 AM
DigitalPunk's Avatar
If it was me I would get the artec crossmember that has the brackets built into it for a long arm upper links, then get the lower Frame bracket and fab up some links :-)
Old 12-18-2015, 03:32 AM
Invest2m4's Avatar
You're backwards on that. The crossmember is for the lower links. You need brackets for the uppers.
While the artec crossmember is plenty strong, I wouldn't trust the stock frame brackets and bolts.
Old 12-18-2015, 04:33 AM
Rebar-7's Avatar
Originally Posted by Invest2m4
You're backwards on that. The crossmember is for the lower links. You need brackets for the uppers. While the artec crossmember is plenty strong, I wouldn't trust the stock frame brackets and bolts.
haha the thought crossed my mind when I saw that one with the brackets. And yes
Invest it seems all the stock brackets are thin and look weak
Old 12-22-2015, 06:12 PM
TweakJK's Avatar
I have the artec crossmember with brackets, its beef. You get a pretty good workout installing it. Everything lined up to the bolt holes perfectly. If you are building your own links, this is the solution.
Quick Reply: JK Heavy Duty Crossmember
