JK Heavy Duty Crossmember
So I've come to the point were I need to replace the cheesy stock tranny crossmember on my 13' JKU.
Im looking at Artec or Poison Spyder for replacement options would appreciate any feed back from people
That have ether . Thanks
I've the PSC its well built but I'm sure the Artec one is built equally well.
If you got rid of your cross member how is the rock hard skid mounted? I have the same skid and required me to bolt to the cross member, I also would be worried about the frame tweaking if you don't have a cross member in place.
I was under the impression the op was talking about the really light duty piece that took the place of the skid plate in front of the actual cross member. I have a 14, I thought on the older JKs there was originally a skid plate but they redesigned it because of fire starting from dried leaves and other debris accumulating.
If, on the other hand, you are referring to the bigger one that supports the transmission itself, then that's a different story. I've heard good things about both the PS and Artec, although I have no experience with either.
There is only one part on the Jeeps called a crossmember.... lets stop the misinformation. To the original poster, both are solid and you won't notice a difference... go with what brand you want to support.
crossmember FYI
crossmember FYI
Yes I'm talking about the actual cross brace that the tranny bolts to. I have the Rockhard engine/ tranny skid also.
The thing is that I've found that over time from wheelin the stock cross member is actually compressing then I have to re tighten
The bolts that go into tranny mount and skid plate. The stock cross member is made of only 16 or 14 gauge sheet metal.
this is the one I'm really looking at but it says it uses 3/8 course thread captive nuts instead of the stock M12 fasteners. Thinking that must be where it bolts to frame brackets on either side ?
I have the PS and it is easy to install and much beefier than stock. It mounts perfectly. an exact precise fit 100% simple install.
I went thru NR4x4 got a great deal and fast shipping. they had it dropped shipped from PS and was here in a couple of days.
Were it bolts to frame brackets then.
