Jk exhaust
Jk exhaust
Allright, there are so so many exhaust systems out there, Most recently I saw the ARB Cat back system, they actually have a video with sound so you can hear it. Anyway with that said what is the best for the price there all about 300 bucks or so but I am sure someone out in the JK-Forum has installed one taken one off or has helpful advice.
Any advice would be awesome
JK-Forum Founder
are you asking if anyone has run the ARB exhaust or just looking for people who are running an aftermarket one in general? if it's the later, i am running the rancho exhaust and really like it a lot. it's an easy bolt on application, sounds great and is priced reasonably.
I relocated it but didn't use any kind of kit, just go down to your local exhaust shop and tell them what you want. I have a 2-door and there is a perfect slot for a 6'' magnaflow race muffler. Sounds great and tucks it up out of the way. Paid just over $100 for the muffler and install.
I am running the magnaflow system I got from another forum member. I love the sound and it doesn't resonate at all. I think they run a little more new in the $500 range. The muffler is in the stock location, but it is much smaller and a little more up out of the way. The only problem I had with the install was that I had to get a couple rubber hanger connectors/isolators from the autoparts store because the placement of the hangers caused a vibration from time to time. The longer hanger Isolators did the trick and were less than $10
I used an Dynomax Ultraflo " Bullet Race Muffler " ( only about 6 inches in diameter ) And tucked it up close to the factory heat shield in the factory muffler location !!! I have no worries about rock hits ; since you have to crawl under the Jeep just to see the thing !!
