Jeep overheating with Ripp Supercharger
Edit: just saw the cooler (looks like an inter cooler to reduce charge air temp) so it looks like re-locating that may be a no-go. Test to see how much of the other stuff you have to remove, but remember the need for airflow goes up as outside air temps go up. What's good today may (will probably) not be enough for the summer. You may also be able to fix it with an aftermarket radiator.....
Welcome to the Forum by the way!
The intercooler restricts air flow a bit, but does not completely block it like a big winch, lightbar, and aftermarket "angry" grill. I really think that aftermarket grill is the main contributor to the problem.
Hood Vents
I say if your willing to throw money at it. Get some daystar Hood vents. It can't hurt to try it and if it doesn't work its still looks bad ass. I'm probably going to get these eventually. Just add it to the list..
Amazon.com: Daystar KJ71048BK Black Hood Vent Kit for Jeep JK - Pair: Automotive
As someone mentioned, remove the winch and light and drive around for a bit to see if the issue can still be reproduced.
This will cost you nothing but a little time and will help troubleshoot before figuring out what to do next.
Start with the free stuff first. Just takes a little time to remove a light bar and winch.
Swap in the original grill.
research the engine cast sand.
Then try hood vents.
I would have to agree with the remove light bar, because I have a in-bumper mounted winch on my ARB Deluxe bumper. But, I had a double row 15" light bar I had my hubby install on the underside of the bull bar - which then effectively blocked the entire grill area. Even with a Flex-lite dual core radiator I noticed a rise in the temp. So I removed it and all back to normal, even with the Ripp intercooler blocking some of the radiator.
Sponsoring Manufacturer
That's a lot of stuff blocking airflow to your radiator:
* Aftermarket grill with smaller openings - blocks top of radiator.
* Big winch - blocks bottom of radiator.
* The light bar, and the tubing it is mounted to - blocks middle of radiator (and intercooler).
* Intercooler - reduces flow to middle of radiator.
It's almost like you're trying to make your Jeep overheat.
You seem to have plenty of aux lighting. If I were you, I would re-install the stock grill and ditch the light bar up front. I bet that would solve your problems.
Also,
We have to ask if you made sure to re-use the coolant that came with the vehicle, or added new during the supercharger install.
RIPP
