Jeep Leaning to the Right, exploring options....
I know it's not the answer you're looking for, I can't answer your question. But for others looking for an answer on a leaning Jeep, you can also check how your rear springs are indexed. How you install your rear springs can make it sit a quarter inch higher or lower, or maybe more. The fronts are indexed the same if you install them correctly, but the rears have 360 degrees to play with on how you install them. (when I say index I mean where you leave the very end of the coil and how it sits on the perch on the axle...you want to leave both springs positioned the same way)
I had a lean to the right and found the issue on mine. When I wheeled disconnected, the spring came out of it's seat (that groove on the perch) and sat on top of the perch and not in the groove so it caused the driver side to sit a half inch taller. I had reset it once and when I wheeled again, it popped out. So I seated it once again and then put spring retainers on it to keep the spring seated. Now it sits level.
