Jeep leaning?
Old 05-16-2012, 05:42 AM
taco_style's Avatar
just about every jeep i see leans on the right. Mine does it also... its all stock right now and it drives me crazy that it leans.....
Old 05-16-2012, 08:34 AM
Former Vendor
Rock Krawler Suspension's Avatar
Its a long shot but check to see if the coils are all still seated right, during flex it is possible that one did not re-seat right.
RK
Old 05-16-2012, 09:04 AM
JDanderson's Avatar
RK
Never thought of that thanks I'll check
Old 05-16-2012, 09:23 AM
yo_marc's Avatar
Good luck with sorting this out. I've never noticed my JK leaning at all, but used to own a Chevy Avalanche that did. It drove me up the wall. Could never get it to sit right, or figure out what caused it.
Old 05-16-2012, 10:14 AM
Smizar's Avatar
This sounds dumb but have you checked tire inflation?
Old 05-16-2012, 10:26 AM
Coco's Avatar
I've never measured, but mine has leaned noticably from day 1.
I just tell myself it levels out after i get in
At least i feel a little better about it because once in, i can't see it leaning any more.
Old 05-16-2012, 12:02 PM
JDanderson's Avatar
I had the same concept my 240lbs self levels it out when I get in problem solved
And tire inflation is good
Old 10-08-2013, 06:44 AM
Turbobob's Avatar
Mine leans also. Mine has a TeraFlex 3" lift on it. I measured from the frame to the ground, and it seems ok, but measure from the flare to the ground, and there is a difference from left to right. Could it be a body issue & not a suspension issue?? I'm gonna look a little closer & try to figure it out!
Old 10-08-2013, 08:31 AM
wittys-jk's Avatar
I agree with one of the previous posters, it depends on the grounding as to how and when it leans. I notice it sometimes in different parking lots and like a fool I find myself holding out my hand to the top of the front or rear fender and then measure where it lands on my chest, I hold my hand there and walk around and see if the other fender is the same height. I think its optical illusion because I have actually measured it and it is barely off. My friend calls his lean his Jeep's gangsta lean.
Old 10-08-2013, 08:50 AM
Zoglmann's Avatar
Mine also leans. Doesn't bother me since most I see lean just the same. It's a jk thing I think.
Quick Reply: Jeep leaning?
